Looking to order today/tomorrow - please advise on parts to complete custom loop :)
14 Nov 2012
Chesterfield
Ok, so since I'm having issues with shifting my Titans, I may as well complete my custom loop considering I have the majority of the parts. So far I have...
1x EK Copper CPU Block
1x XPSC D5 Vario Pump & XPSC Acrylic Tank
6x 16/10 Chrome 1/4" Compression Fittings
2x EK GTX Titan Full Cover Water Blocks
3x 140mm Akasa Vipers
What do you think about the clear tubing?
Would red tubing be better or should I go with clear tubing & red coolant.
I've also listed the red compressions fittings as I think they'd look smart but they can be changed.
This is what I plan to get....thoughts?
YOUR BASKET
2 x Coolgate CG280 280mm Radiator - Black £59.99 (£119.98)
1 x EK Water Blocks EK-FC Terminal DUAL Serial - Plexi £29.90
2 x Akasa AK-FN063 140mm Ultra Quiet Viper Cool Fan - 3/4 Pin £9.95 (£19.90)
2 x EK Water Blocks EK-AF Angled 90 Degrees G1 / 4 inch - Black £9.95 (£19.90)
1 x XSPC LCD Temperature Sensor (Red) V2 + G1/4" Inline Sensor £8.99
2 x EK Water Blocks EK-AF Angled 45 Degrees G1 / 4 inch - Black £7.90 (£15.80)
2 x Primochill Primoflex Advanced Tubing 16/10 - Clear £5.99 (£11.98)
2 x Mayhems Ultra Pure H2O Watercooling Fluid 1L £4.99 (£9.98)
4 x EK Water Blocks EK-ACF Fitting 10/16mm - Red £4.15 (£16.60)
Total : £253.02 (includes shipping : Ex.VAT).
I disagree on the water temp. Its very useful to see whats going on in your water loop and where you might have issues.
+1. its always good to see what is delta water temp and how your loop is performing.
That was my intention! I know the coolant has a limit so want to make sure it doesn't get to that limit :D
Do you have UV lighting already?
Will you mostly be usingthe PC in the dark?
If not, blood red.
I preferred blue myself, though.
No, I was considering some white LED strips to put in and thinking about it now, I may just get the water and change to a coloured liquid later on.
So far it looks like this:
YOUR BASKET
Total : £223.12 (includes shipping : Ex.VAT).
Now I know OcUK don't have the correct plexi block for my GPUs so wondering what else I could use to bridge them?
Akasa 140mm Viper are very good fans. Rated static pressure is 3.12 mm/H2O. Only problem can be their yellow color. For my latest build I have painted 3 of them to white. But they do the job.
I've got 3 in my case which arrived yesterday. Reduced my GPU temp by 10c :eek: Superb fan!
Can you not order that part elsewhere?
I could but I'm not sure I'd get it in time for building at the weekend!
