Looking to order today/tomorrow - please advise on parts to complete custom loop :)
14 Nov 2012
Chesterfield
Ok, so since I'm having issues with shifting my Titans, I may as well complete my custom loop considering I have the majority of the parts. So far I have...
1x EK Copper CPU Block
1x XPSC D5 Vario Pump & XPSC Acrylic Tank
6x 16/10 Chrome 1/4" Compression Fittings
2x EK GTX Titan Full Cover Water Blocks
3x 140mm Akasa Vipers
What do you think about the clear tubing?
Would red tubing be better or should I go with clear tubing & red coolant.
I've also listed the red compressions fittings as I think they'd look smart but they can be changed.
This is what I plan to get....thoughts?
YOUR BASKET
2 x Coolgate CG280 280mm Radiator - Black £59.99 (£119.98)
1 x EK Water Blocks EK-FC Terminal DUAL Serial - Plexi £29.90
2 x Akasa AK-FN063 140mm Ultra Quiet Viper Cool Fan - 3/4 Pin £9.95 (£19.90)
2 x EK Water Blocks EK-AF Angled 90 Degrees G1 / 4 inch - Black £9.95 (£19.90)
1 x XSPC LCD Temperature Sensor (Red) V2 + G1/4" Inline Sensor £8.99
2 x EK Water Blocks EK-AF Angled 45 Degrees G1 / 4 inch - Black £7.90 (£15.80)
2 x Primochill Primoflex Advanced Tubing 16/10 - Clear £5.99 (£11.98)
2 x Mayhems Ultra Pure H2O Watercooling Fluid 1L £4.99 (£9.98)
4 x EK Water Blocks EK-ACF Fitting 10/16mm - Red £4.15 (£16.60)
Total : £253.02 (includes shipping : Ex.VAT).
Would personally ditch the fans in favour of some fans that are designed from the ground up for use on rads. Im sure they are quiet but do they actually work well pushing through rads? Also the LCD temp sensor thing. Who cares what the water temp is as long as your hardware temps are fine?
Dont see any other problems as long as the bridge for your cards is the right spacing for your motherboard. Tubing and coolant is personal preference but i guess there is no chance of staining if your running coloured tubing and clear coolant.
I have used mayhems red dye in past and having a hard time now clearing my radiators for new build. whatever i do, rads are staining the flush water. I am almost there where i have to buy new ones. keep that in mind :-)
I disagree on the water temp. Its very useful to see whats going on in your water loop and where you might have issues.
+1. its always good to see what is delta water temp and how your loop is performing.
Yep you can easily work out then whether your cooling could be improved by a better/more rads or different fans.
Or in my case when I put my new motherbaord in and forgot to connect the pwm fan headers and then went stress benchmarking my rig for stability, almost having a heart attack when the temp led read 65C!!!!!!!!!!
I am surprised it had lasted 20 minutes just running on passive cooling to be honest ;)
That was my intention! I know the coolant has a limit so want to make sure it doesn't get to that limit :D
Do you have UV lighting already?
Will you mostly be usingthe PC in the dark?
If not, blood red.
I preferred blue myself, though.
No, I was considering some white LED strips to put in and thinking about it now, I may just get the water and change to a coloured liquid later on.
So far it looks like this:
YOUR BASKET
Total : £223.12 (includes shipping : Ex.VAT).
Now I know OcUK don't have the correct plexi block for my GPUs so wondering what else I could use to bridge them?
Akasa 140mm Viper are very good fans. Rated static pressure is 3.12 mm/H2O. Only problem can be their yellow color. For my latest build I have painted 3 of them to white. But they do the job.
I've got 3 in my case which arrived yesterday. Reduced my GPU temp by 10c :eek: Superb fan!
Can you not order that part elsewhere?
I could but I'm not sure I'd get it in time for building at the weekend!
