Loop order and fan direction
26 Oct 2014
Hi guys
Finally got all the parts for my loop including the ultra hard to find block for my powercolor GPU !!
Anyway my question is this I will have a 360 on top and a 240 on the front and my idea for the loop was
250mm respump combo - GPU - CPU - top rad - front rad - pump res combo. Or would i be better having the top rad between the GPU and cpu in the order??
Also with the fans I have a 750d case by corsair so I was thinking 360 3 fans on top pushing air from outside through the rad into the case... same with the front rad and have a 140 fan as a rear exhaust.... the bottom of the case also has room for 2 more fans so maybe use them as exhaust as well??
Fans will be controlled by a grid v2
Thanks in advance guys
Loop order doesn't matter as the water temp will equalize, so just do it in what ever order is easiest or looks the best.
