Lorne/Square Sausage
22 Aug 2010
On the Wagon-East Angular
Aaages ago, Asda used to sell lorne sausage and it was really nice. Full of flavour and fat. They then stopped selling it.
Iceland sell the Plumtree Farms stuff but it's utter cack - no flavour or fat, so it's yucky.
Is there anywhere near me (Norfolk) that sells decent lorne sausage? My local butcher doesn't sell it, and I'm *fairly* certain most supermarkets round here don't either. I'll give making my own a bash at some point, but and ideas as to where to buy it off the shelf would be great.
Only place to get decent square sausage is out a butcher but it tends to be Scotland only that does it...
It sounds almost, (almost) unbelievable, but the first 5+ results in a google for 'buy square sausage online' are actually places, where - i know it's amazing, but wait for it - places you can actually buy square sausage online. Incredible.
Did you type your query into the little Google box that can be found at the bottom of every thread on OcUK?
Your smart-arse reply might have been justified if the OP hadn't specifically asked if there was anywhere local he could buy it "off the shelf". Unfortunately, because he did, you've shown yourself up as a right ****.
If Scotland is a bit too far to travel then you'll find it in every butchers and supermarket in Corby too.
Still not close but closer than Scotland!
Heck do square sausages. I think Waitrose and Tesco sell that particular one but don't think all stores stock it, worth a try though.
