Im planning on buying a 10,000RPM SATA HD, just 2 questions if you will gents
1) To install SATA drivers, do you normally get a floppy disk with the hard drive? If not, where can I find the ones I need to use? Are they always generic drivers? Do you encounter many problems installing SATA instead of IDE?
2) If I have a 10,000RPM primary drive for Windows, games, music etc, and buy a standard secondary 7000RPM drive as a backup, will the 10,000RPM primary suffer a performance hit?
P.S. I dont plan to run a RAID setup.
Thanks a lot
Thanks a lot
