Losing receipts
1 Mar 2003
Cotham, Bristol
Now I understand that if you have a bank statement that proves you spent money somewhere you can use that as proof of purchase if you've lost a receipt.
What happens though if you've bought several items for say £100 but you wanted to take back one item that was £10, can you use the bank statement in that scenario? Even though it doesn't give any detail?
I am sure someone can confirm/correct me, but legally you do not need a receipt as a shop is not legally required to provide one at purchase.
Legally you don't need one.
The card statement is enough. Some stores can search their computers for date / time to locate your purchase.
but depending what store it is (large busy chain store for example), would they bother looking up the transaction, especially if it was a low value purchase?
It doesn't matter if they are bothered or not, they have to do it as you are entitled to return faulty/incorrect [as in not fit for purpose or not as described] goods.
A bank statment only proves that you spent x amount in the shop though. Not what you spent it on. Obviously different if they can look in their machines to find out that it was you, but it would be difficult in most places to find it out without going high up in the food chain.
Personally i have a system.. electrical items or stuff i know will break scan onto PC and bin other wise dump into a little box which gets emptied every 3/4 weeks so if needed can find it. I'm very odd/tidy :(
I'm sure the store's main priority is to just see that the items are of the same value.
Better than most.
I have a bad habit of misplacing receipts.
