- 6 Jan 2011
- Stoke on Trent
I just put this card in but Nvidia control panel wont show 144 hz just 50 59 or 60 connecting to my Benq Q 144 hz monitors. Updated new drivers. ThThey are connected via DP.
I beleive the HDMI on the monitors is 1.4 but i dont think it give only 60 hz. I was running surround with two DP and one DVI on my 1080ti but have dropped down for now to two monitors as i needed the third DP free for VR.
So after solving this problem if there is a solution would it be better and simpler to just disconnect the third monitor and plug in the VR headset as and when I need to if I go 3 DP cables or would a HDMI to DVI at back of monitor cable work, so the third DP on the card is empty for VR?
