- 5 Aug 2018
Evening gents,
So I've had my 2700x / 1080ti setup for a while now and my ancient viewsonic monitor is starting to flicker and could do with replacing.
However I am completely baffled by all the options there are these days!
Ideally I am looking for something 24-27inch but no bigger and happy to spend anywhere between 300-450ish, but that's the easy bit!
Now from what I've read i should be looking at a minimum of 144hz but I have no idea if g-sync is worth shelling out for? There's also adaptive sync but I believe this is actually amds freesync so will not work with the 1080ti.
Also 4k vs 1080p? Having only ever used 1080 is 4k worth sticking at 60hz for the size I am looking at?
Any help, advice or suggestions would be much appreciated!
