Lost Partition - Recovery ?
12 Jun 2005
Durham / Shropshire
Ok, hard task I know.
But I lost a Partition on my external harddrive with all the 14gb of vital data (my documents etc - to transfer onto my new install :s )
I have tried loads of 'free' software, but they let you find all the files etc, but then ask for an activation key or to upgrade to recover all the files.
I know the files are on the harddrive but i cannot get access to them :(
I have tried the following:
Test Disk - worked for one parition, can't get it to recover second - any help appreciated
Virtuallab Data Recovery - Picks it all up, tho wants activation
Get Data Back for Fat
PC Inspector File Recovery etc etc, but most ask for some sort of activation, despite them being available as 'free'
Test Disk seems to be the best, despite it only operates in DOS, tho can anyone help guide me to rescue my final partition on the disk?
Any help would be gratefully appreciated; do you know of better free software?
Cheers
Ian
Frankly there is no free software I know of that performs this role. I reccomend easy recovery pro 6, although it costs a fortune.
Have you tried something like Kinoppix (Linux that can be booted from CD) That might be able to see the partition and allowyouaccess to it to get your files back.
I also don't know easy free software that can do it.
I used GetDataBack a while back for a mate and it worked very well but it is $79
