So I received my computer back, this was the technicians report:
(SYSTEM REPAIR: Other (Not Listed), Component Failure, PSU was replaced due to clicking whilst under load, replaced with an alternative as requested. Tested the system. System was crashing on blender when we were running a render test. Re-installed windows and all of the drivers then re-tested the system with no further issues.)
When I booted it up, the bios had been reset to default and windows 11 had been factory reset. After installing windows 11. I installed the drivers from the motherboards website, and I reloaded the overclocked bios profile that they had saved, I ran Prime 95 and got two errors within 11 minutes. But the good news is the PSU isn't making any clicking sounds.
Prime 95 results example
worker #1
Fatal error: Rounding was 0.4975535683, expected less than 0.4
Hardware failure detected running 360K FFT size, consult stress.txt file
torture test completed 3 tests in 5 minutes 1 errors, 0 warnings.
Worker stopped
worker #5
Fatal error: Rounding was 0.4.998537884, expected less than 0.4
Hardware failure detected running 4608 FFT size, consult stress.txt file
torture test completed 12 tests in 11 minutes 1 errors, 0 warnings.
I tried again after completing all of windows updates the same issue.
I cleared the CMOS battery loaded the same saved overclocked profile. Same issue.
I ran a memory test from the bios it came back with zero errors.
The whole time I only had a keyboard, mouse, ethernet and monitor plugged into the ports.
I reset the Bios back to default, ran Prime 95 for 30 minutes and there was no errors. The CPU was running around 4.7ghz the ram defaulted to 2.4ghz instead of 3.6ghz.
I tried their overclocked profile again which changes the CPU to 4.98ghz but I left the ram at 2.4ghz, and prime 95 still came back with similar errors.
I formatted the drive installed windows 10 instead of 11, installed all the drivers and updates, same issue.
Since receiving the PC back the temperatures seem slightly higher. Its worth noting that the room is 2 degrees hotter than it usually is. As the thermostat reads 24 and its set to keep the room at 22.
Idle
CPU temp before 34 degrees now 37 degrees
CPU Package temp before 35 degrees now 40 degrees
GPU temp before 27 degrees now 27.5 degrees
Under load:
CPU temp before 78 degrees now 84 degrees
CPU Package temp before 86 degrees now 95 degrees
I'm guessing the reason the technician received no errors in prime95 after reinstalling windows and drivers, was because they had reset the bios back to default without realising. Its the only way I don't receive any. Or am I missing something?
Some websites online state the prime95 errors don't really matter unless you're rendering or gaming etc. But I render all the time which usually pushes the CPU constantly to 100% on all threads for 2 hours at a time. And I game, but nothing as intense as that. Just GTA 5 and dying light atm.
I haven't installed any games or tried to render anything at the moment. As its a headache to install it all, and figured its best to have nothing but windows installed whilst testing.
I know a comment above said that this means that their overclock isn't stable (which is something I paid them to do). Does this need fixing? What do y'all think?
