Loud hard drive grinding
27 Oct 2007
I built my brand new PC two weeks ago and reused my old 1TB HDD from my old build (which was built in 2009).
The HDD spent two days out of a case and wrapped in a anti static bag and was safely stored.
However, since day one in my new build the hard drive has been making very loud grinding noises. When I first boot it for a hour it makes a loud grinding noise but after this time the noise seems to die down with the occasional scratch/grind every 5 minutes or so. In my old build it never used to make such a sound
It will do this throughout the day and when I scan my computer with my anti virus, the grinding starts again and gets so bad it sounds like its going to blow up. It also does this if I was waiting at a loading screen of a game.
I know this is not a fan issue because I have located the sound and checked that there are no wires in the way of the fans.
Is this a sound of a dying hard drive? I hope not, I really can't afford another one =/
Thank you in advance :)
might just be that your old system managed the hard drive vibrations better. If you apply pressure to the drive while its making the sound (ie press your finger on it) then does the sound go away?
