buy prime i mean make sure its full of fluid so there is no air and also it has head pressure as in enough fluid pressure at inlet to give continuos flow.
tbh it sounds like its full from what you just said but there may well be pockets of air restricting flow else where.
cant hear a murmor from mine and its on my desk in a separate control unit to my pc
and its on the rubber or foam pad and locked in place by the rummber mounts that come with it.
even tho you dont see bubbles at the pump inlet or out let there may well not be full "prime" or flow thru the system if theres is an air lock somewhere else that you cant see.
worth doing the pick it up or move it all about bit to see if you get any air to bleed out. imo
and also because your header looks topped up doesnt mean to say theres no air else where untill you make sure any air has worked its way out as in the statement above
it still could be a damaged impellor in the pump mind you or a lose one. rattling around in there
