It is Low!
What res are you running at? leave it at deault. Also make sure you are not forcing FS AA of AF in the nvidia control panel. I have a similar rig you should be hitting about 14K
Jonnygrunge.
Installed new gpu drivers/removed the old ones? is anyything running in the background?
I don't think that is low actually, not if you're running stock @2.4ghz. A mate has a similar setup to you. BFG 8800 GTX OC2, 4gb ram, vista64 but with an e2180 @3.2ghz and he scores about 11300. When i was overclocking my e2180 to 3.2ghz my 3dmark score was flying up every 2-300mhz i did. I reckon if you were running at about 3.4ghz (like a lot of e6600's do) you score would be a lot higher.
I don't take too much notice of 3dmark06 scores these days. My mates system is exactly the same as mine. That includes overclock and memory timings, apart from he has the 8800gtx oc2 and i have 8800gt OC. We score about the same in 3dmark06 1280x1024 but when playing crysis @1680x1050, his is noticeably faster
Nah thats about fine for a stock system, could be abit higher I suppose.
That board can take 1333mhz FSB as my friend is running the same board and exactly the same chip as that. You will need to flash the BIOS though.
thats why its been sitting in my drawer for 3 months, im not sure how to flash it, ive read the instructions but it sounds hard![]()
Ive got a e6850 sitting in my drawer for the past 3 months, i wonder if id get much of a boost from that.
What you been doing with an E6850 in your draw? Is it new or something. flog it.
Well ive just put in my e6850 and ran 3dmark06 and my new score is 11493 thats 1153 more points.
Is that score ok, or should it be a lot higher. Im gonna have a go at crysis now see if i notice a difference.
