Low Budget Help
27 Nov 2010
My parents have agreed to get me a computer, however their budget is only at around £300 (I can probably get it a little bit above). Could anyone spec me a system? I don't need an OS since my friend has a spare install, but I will need a monitor+keyboard so maybe take a bit off for that.
I'm willing to wait for pieces to come up cheap, so it would be really helpful if someone could point me towards the kind of parts I should be looking at. Thanks!
£300 including monitor? That's gonna be extremely tough, might be worth getting a low-end laptop from PC World or something. What will you be using the PC for?
Mainly for gaming and photo editing / graphics work. I might be able to get a monitor off one of my friends though.
Not a hope of anything reasonable I'm afraid.
Low spec Core2Duo system with *possibly* 2GB of ram and a G31 chipset.
But you won't have dedicated graphics so it will just fail at games.
BenQ G2222HDL 21.5" Widescreen LED Monitor - Black
(£93.61) £109.99
Coolermaster Elite 430 Windowed Case - Black (with 500w Elite Power PSU)
(£53.61) £62.99
Asus M4A78LT-M 760G (Socket AM3) DDR3 Motherboard
(£41.69) £48.99
AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3) - Retail
(£35.74) £41.99
Samsung SpinPoint F3 500GB SATA-II 16MB Cache - OEM (HD502HJ)
(£27.22) £31.98
OCZ Gold 2GB (1x2GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Single Channel Module (OCZ3G1333LV2G)
(£21.27) £24.99
Sub Total : £273.14
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £11.75
VAT is being charged at 17.50% VAT : £49.86
Total : £334.75
Thats the best I can do, and still no dedicated graphics card, and still over budget!
Thats really helpful Cookeh, I think my friend has actually got a spare monitor so that is actually well below budget =)
(£93.61) £109.99
(£53.61) £62.99
Intel Celeron Dual Core E3400 "LGA775" 2.60GHz (800FSB) - Retail
(£32.33) £37.99
MSI G41M-P25 Intel G41 (Socket 775) DDR3 microATX Motherboard
(£29.78) £34.99
(£27.22) £31.98
(£21.27) £24.99
Sub Total : £257.82
DPD Next Day Parcel
VAT is being charged at 17.50% VAT : £47.17
Total : £316.74
Slightly less over budget, but much older tech. Still no dedicated graphics. Still no keyboard.
Do you not have any money you could contribute to this?
If you dont need a monitor in it, and can go 50 over, you can get a very reasonable system for 350
Gainward ATI Radeon HD 4870 "Golden Sample" 512MB GDDR5 PCI-Express Graphics Card - OEM (Grade A Refurb 3 Months Warranty) £79.99
Patriot Viper 4GB (2x2GB) DDR3 PC3-12800C7 1600MHz Dual Channel Kit (PVS34G1600LLK) £63.44
Coolermaster Elite 430 Windowed Case - Black (with 500w Elite Power PSU) £62.99
Asus M4A78LT-M 760G (Socket AM3) DDR3 Motherboard £48.99
AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3) - Retail £41.99
Samsung SpinPoint F3 500GB SATA-II 16MB Cache - OEM (HD502HJ) £31.98
LiteOn IHAS124 - DVD±RW (±R DL) / DVD-RAM drive - Serial ATA - 48x (CD) / 16x (DVD) 48x (CD) / 24x (DVD±R) /12x (DVD±R DL) 32x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 12x (DVD-RAM) - Internal - Black £11.97
Sub Total : £290.52
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £10.50
VAT is being charged at 17.50% VAT : £52.68
Total : £353.70
If your budget was £400 this would be easy to build a very nice pc. This is the best I could do
For £360 (including postage :eek:), you could get this:
HIS ATI Radeon HD 5770 1024MB GDDR5 PCI-Express Graphics Card
(£85.10) £99.99
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9)
(£56.16) £65.99
(£53.61) £62.99
(£41.69) £48.99
(£35.74) £41.99
(£27.22) £31.98
Sub Total : £299.52
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £10.00
VAT is being charged at 17.50% VAT : £54.17
Total : £363.69
Still no keyboard, but you can pick them up for £5 in a well known high street shop.
System will out perform the Primo by a mile, and will be decent for games (depending on the resolution, which I don't think is going to be great seeing as you're getting one free from a friend ;)) and editing.
Oh snap! Ive been forgetting optical drives all this time!
Ima blame the fact I haven't used one in over two years :o
Again, over budget but slightly more powerful integrated graphics.
EDIT: Why don't you save up? £400 will get you a better PC.
For a bit more you can add a 460 and/or better mobo, but you can keep going all day, try n stick to your original budget, the build above should be sufficient for most things still
HIS ATI Radeon HD 5770 1024MB GDDR5 PCI-Express Graphics Card £99.99
AMD Athlon II X4 Quad Core 640 3.00GHz (Socket AM3) - Retail £75.19
Sub Total : £335.79
DPD Next Day Parcel
VAT is being charged at 17.50% VAT : £60.60
Total : £406.89
