- 5 Dec 2010
- Solihull
Hybrid or Dual... To be honest, I thought they were the same thing, or rather I thought DUAL was like some of my Laptops, in that they have Intel GFX and then nVidia for gaming, and they could switch between the two.
Either way, its using both the CPU and GPU in whatever format they are!
Erm, I am looking at my stuff and the last time I played with that CPU plus Card thingy, was my AMD A10-6800K PC. Its got a Gigabyte F2 A85-XN Motherboard, 240GB SSD and 3TB WD Black.
I compared the OnBoard of the CPU With an ATI 6600 Card and also in dual or hybrid crossfire and the card on its own, just to see what I got... I also tested an ATI7700 on its own too and the single 7700 was of course vastly quicker... But it was fun all the same. I still got that machine and its used purely for backing up my6 Atari Falcon stuff and as it has a ZIP Drive, I am using Vista64 on it - Newer versaions of Windows no longer support the ZIP Drive.
I had thought of toying with a Ryzen with Dual or Hybrid Graphics, just to see, but again, this would be a waste of time I recon.
Its the finding of compatible GFX Card that are a pain and Im not sure that the Ryzen does it any anymore anyway?
Forgive my ignorance, but wasnt crossfire done in this way?
Unlike SLI that shares everything, crossfire worked my having a master and then delegating tasks to the slave cards?
I was told but I have clearly forgotten. ( Like everything else in my head )
Well, when talking about crossfire, SLI, you're probably talking about AFR (Alternate frame rendering). One GPU in the array would render a frame, then the next GPU then the next one or back to the first one. SLI and CF didn't really work any differently but CF was a bit more flexible with the GPUs that could work together.
There's no Dual Graphics fun to be had with Ryzen onwards, unfortunately. That finished with the FM2 APUs like the one you had.
But in my last comment, I wasn't really talking about SLI / CF. I've accepted that multi gpu is long dead at this point. Just that it'd be good if some work could be offloaded to a secondary weaker GPU to benefit the primary in a gaming situation.
