hw monitor had max temp 72 degrees, 54% fans. not sure actual GPU usage.
That would tell you if you were cpu bound or not
I capped mine at 60fps to smooth things out. Occasionally drops below by a few fps, but never noticeable. Interestingly my CPU hovers around 50% and so does my GPU. Maybe I should try it without the cap again as I think my PC was updating when I tried it last time.
I guess either my i7 4770k or 8Gb Ram is starting to hold me back at 1440p with Ubisoft's current engine. 1080Ti graphics card, doubt that is the problem.
Was probably that big windows update just past.
