Hi All,
i seem to be having issues with fps since i added my new gpu to my rig. My spec is as follows;
i7-4770 - Z87 - 8gb - gigabyte geforce 780ti Windforce and a seagate psu.
Ive tested the following games;
B4 - load up i get 60 fps, in game between 30 and 50 on max settings. ive turned v-sync off in game and through control panel. Ive read i should be getting plenty more?
ACBF - Again, load up is around 60 fps. However, in game is below 30 and as low as single digits. Again, have tried with v-sync off in game and through control panel.
Titanfall - Had loads of fps on load up and around 40 to 60 in game.
Surely i should be getting more than this? ive spent nearly £2000 on my upgrade now and expected things to run smoothly for a while.
Also, loading screens are incredibly slow. Titanfall for example took nearly 5 mins to load. when i finally got in game i was already well behind on scores.
Have done benchmark test on Heaven Benchmark 4.0 and my highest score was 1100. looked up similar spec pc and they had nearly 2000.
hoping someone can help?
