Low framerates on HD4670
16 May 2009
My 4670 seems to be lacking a bit for some reason. on World of Warcraft im running it at about 20-28 FPS and before when i had my GT9500 i was running at about 40-50, this makes no sense because my 4670 is so much better.
Any ideas?
Erm, the last time i tried that i ended up deleting one of the programs needed for my internet connection, and it was labled as an NVIDIA program.
Any safe way for me to know?
probably because you have a nvidia chipset. But just to check could you post your build?
EDIT: one way to find out is to just put the GT9500 back in and see what the pc is like. You normally can see and feel some "lag" when your moving the mouse around the screen which normally means there are no drivers or the wrong drivers have been installed.
To uninstall i would keep the 9500 plugged in, go to device manager and find Display Adapter. When you click on the little expander box (little box with a cross) you should see Nvidia Geforce 9500GT, then just double like it, go to the "Drivers" tab and click uninstall.
After that put the ATi card back in and install the drivers. Should be fine then. (If you've done this already then ignore me!!)
I don't get it. I run crysis mid/high settings at 30-40 FPS but cant run wow at higher? Lol, it makes no sense. i think its something to do with something else..
