- 17 Mar 2004
Whats the damage of running a car with low oil. Just on my way out and driving my fav back roads, and the Orange oil light comes on. I believe it goes red too.
I pulled to the side of the road and turned the engine off, then on and the light went out.
So I drove to my local Frauds, and parked up, turned the engine off, and the orange light come on again.
So I checked the oil (engine was warm, but alas minimal oil on the dipstick level) below the min mark.
So just put a litre of 0W-30 Castrol in and driven home.
Another well done to Wollaston Motors. I have only had the car 3 weeks, and done around 1,000 miles on it. So they either did not check it, or the car has burnt loads of oil.
Anyway, am I likely to have damaged my E46 330 engine?
Be it low oil level or low oil pressure that the light is indicating, the effects are the same. Low oil pressure (with the exception of worn engines) is generally caused by low oil levels.
