Low power rig with some oomph
9 Dec 2002
in a hole in the ground
My rig is now about 9 years old and last upgrade was an 8800GTX other than an 128 Gb SSD.
It is mainly used for serving up videos around the home and torrents. Which is why i'd like it to have low power consumption.
Every now and again I want to process photos in lightroom and also edit my HD videos. So needs to have the processing power to whizz through this.
Gaming on my PC is a thing of the past :(
I have a full tower case - but would be happy to consider something smaller and put in a couple of bigger drives.
Any advice much appreciated.
Adam
Can you post your current spec, including make, model and age of Psu.
Are your hdds and dvd/rw sata. Do you have an after market cooler and OS.
How much photo and video editing do you do?
Budget wise I guess around £500.
Antec 900 Nine Hundred Ultimate Gaming Case - Black
Corsair HX 620W ATX Modular SLI Compliant Power Supply bought in 07
Core2Duo of some kind with Gigabit mobo
All drives are SATA
Got some kind of Noctua cooler -have a feeling i may have damaged it when I installed it all those years ago.
I guess i process a couple of times a month for a few hours each time. It becomes quite laborious as the machine feels underpowered.
I have about 6 or 7 HDD's spilling out of the machine which are various sizes.
thinking about it - i'd also quite like to run hyperV VM's as well for personal learning - not for production systems so performance isn't crucial.
Your Psu should still be fine and you can reuse your dvd.rw, if you have one. Included 16gb of ram to help with the editing. You can always add an aftermarket cooler when funds permit and will help, if you decide to OC above 4.2Ghz.
YOUR BASKET
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £189.95
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £85.99
1 x GeIL EVO Leggera 16GB (2x8GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (GEL316GB1600C9DC) £83.99
1 x **B Grade** Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (S (HD-255-SE) £62.4
1 x Corsair Carbide 200R Compact ATX Case - Black £49.99
You canuse your ssd for the OS and the hdd for storage, your other drives you will give you more storage and help with backing up files.
Total : £484.32 (includes shipping : £10.00).
looks good - do you reckon the onboard gfx will be good enough? wondering if i need to use the original graphics card? do they use much power when idle?
