Caporegime
- 9 Nov 2009
- Planet Earth
@ CAT the op is after a budget CPU for gaming, look at the graphs, under £50 notes gets you that performance, why spend anymore?
If you wanted to build a mid to high end rig that would be a different story..
The Haswell Pentiums are perfect for budget, low power PC's.
It since the performance charts are cherry picked and even by your purchases choices you go for a faster CPU with greater multi-threaded performance. Its one thing for WoW which runs two core but you do it in all threads.
Even games like Crysis3 and BF4 you would push them,even though after you actually play such games you would realise how much fail a dual core is in THOSE games.
Remember the last thread,where you went on how Intel had destroyed AMD's performance lead. Then people repeatedly told you that it was some issue,and in the end it was??
