Recently put together a new system, using a micro case, the problem i have is that my huge ak-965 cooler (so big i can't fit a side case fan) has a side on fan which doesnt get much air flowing to it, causing my e5200 @ 3.33ghz to run high 30's idle.
If i had a low profile or top down cooler i could mount a nice big 12cm fan or cpu tunnel on the side of the case provided direct cold air into the cooler.
- any suggestions for a decent cooler of the above description that is small enough to fit in the micro case and enable me to have a nice big side case fan.
- the ak 965 is measured at 138.4 x 105 x 58mm (not sure which measurement is from motherboard to side of case, will measure later) and the case is 18cm wide.
- also anybody want the ak 965 at a reduced price with box etc used for a few hours?
