- 17 Aug 2003
- Woburn Sand Dunes
I would assume that also but baths arent the only use of hot water feeds, remember. Showers, sinks etc. if the hot water never gets hot enough, the bacteria can thrive in the hot pipes (which gets worse the longer the water is left stagnant) and you might well find yourself spraying lukewarm legionella-laced water in your face when you take a shower. I doubt shower gel would have much of an effect then.I suspect surfactant based products I.e soaps and shampoos would further hamper the bacteria in getting a foothold
The guidelines are there, it's our choice to follow them or not. Well, unless you are a landlord or business owner in which case you are legally bound to minimise the risks.
https://www.emhhomes.org.uk/living-in-your-home/safety-at-home/legionella/
Health and Safety legislation requires landlords to check water systems found in the home for Legionella bacteria. The bacteria cause a form of pneumonia called Legionnaires disease.
Because we are committed to protecting the welfare of our tenants and employees, the following guidance will help you prevent Legionella occurring in your home.
When you first move into your home, run the bath and hand basin taps continuously for at least five minutes. This will flush through any bacteria.
If your shower has not been used for a week or more, run water from both hot and cold supplies through the shower hose and showerhead for two minutes. To ensure no spray escapes from the showerhead, run it through a bucket of water or full bath.
If your shower has not been used for two weeks or more, disinfect the showerhead. The showerhead should be removed and the shower run for two minutes. The showerhead should be disinfected before being re-fitted by immersing for at least an hour in any solution designed for cleaning baby feeding bottles (e.g. Milton). Showerheads should be regularly disinfected about four times a year.
Raise the temperature to 60°C or higher. Temperatures above 60°C will kill Legionella bacteria so make sure that the temperature of the hot water in your boiler/cylinder is set at a minimum of 60°C. Beware of burns and scalding and take extra care if you have children. Legionella can survive in low temperatures, but thrive at temperatures between 20°C and 45°C.
If your property has been empty for a while (e.g. after a holiday), flush the whole water system for two minutes or more. First flush your toilet, then let the kitchen taps and the hand basin taps run for two minutes or more to let both hot and cold water pass through. Next, flush the shower through as described above. Finally, let any other taps run for two minutes.
