Almost next to my PC stands a freezer/refrigerator, if I build water-cooling
would it then be possible to "borrow some cold-ness" from over there ?
My very simple plan is to make a 10 liters reservoir connected to the little
reservoir in the PC, (directly or indirectly), and external pump controlled
by a sensor in the little reservoir starting the cold flow when needed
I could imagine that the water temperature hitting the Cooling Block could
be reduced 10-15 deg relatively easy if the project is well done ,....
1. but would the effect in real-world be notice-able ? (Q6600 clocked)
2. how low could I take temp without condense/humidety problems ?
3. Is the hole idea possible or just sick ?
Sorry I had to ask
Sorry I had to ask
