Hmm how fast are they? Comapared to a normall ''netburst'' p4 ?
Another option is to look at the VIA all-in-one motherboards with EVERYTHING onboard (graphics, 1Gb ethernet, USB, SATA, ...). They have a number of passive and actively-cooled options. And they're tiny. Really tiny. Try searching for VIA and the brands ITX, Nano-ITX and the new Pico-ITX.
You can stick Windows or Linux on them. I have personal experience of using Linux on an older model as a mail, file and Squeezebox server. It's on 24/7 and it's usually over a year between reboots.
There is at least one UK company specialising in selling these (plus all the accessories you would need: cases, memory, ...). I don't see them as offering direct competition to Overclockers, but I'll play safe and not link to them.
Nothing but praise for the Yesico, it never skipped a beat.
I ran the Q9550 with passive PA120.1 with just over 1v. The new batch Wolfdales have VID of 0.85v IIRC. Easily passive cooled.
I have a hush PC I bought about 2-3 years ago, doing all the stuff you require, and is passively cooled, great except for one fairly major point.
I assume by your post that this will be in a bedroom in which case, as Minstadave alluded to, you really, really want to use solid state disks.
When there is no constant fan noise to hide it, the constant changing pitch of HDD noise will drive you totally mad.
Solid state disks are prohibitively expensive, but if you are really serious about it being silent (or even close to) and you wish to retain your sanity, then they are the only way to go.
