** LOWEST PRICE 4K MONITOR YET!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Were offering a crazy price on a Viewsonic 4k 28" monitor aimed at professionals, hence the catch is its 30Hz, so not ideal for gamers, but for those doing professional work this is very suitable. CHECK IT OUT!
Viewsonic VX2880ML 28" 4k 30Hz 1ms Widescreen LED Monitor @ £379.99 inc VAT
The ViewSonic VX2880ml is a 28” 3840 x 2160 Ultra HD display that provides the highest resolution available in a desktop monitor. Delivering four times the pixels of Full HD displays, the VX2880ml features 4K resolution, 1.07 billion colours, and a 50M:1 Mega Dynamic Contrast Ratio for the ultimate in image colour, clarity, and detail. Versatile connectivity options include HDMI (MHL) for connection to smartphones and tablets, as well as dual DisplayPort inputs and one DisplayPort output for daisy-chain functionality. Dual integrated speakers provide enhanced audio for great multimedia and entertainment performance, while a VESA-mountable design offers additional convenience for use as a wall-mounted display. ViewSonic’s proprietary Flicker-Free technology and blue light filter helps to eliminate eye strain from extended viewing periods. The ViewSonic VX2880ml is the perfect 4K multimedia display for power and professional users, including CAD/CAM drawing, content design, and development applications.
This 4K2K Ultra HD display provides the highest resolution available in a desktop monitor. Featuring a 3840 x 2160 pixel screen that contains more than 8 million pixels, this ViewSonic display has four times more pixels than Full HD resolution displays. In addition, the large 28” display can simultaneously display two inputs on the screen, maximizing productivity while delivering the ultimate in image detail and clarity.
With innovative 10-bit colour processing, this display can generate up to 1.07 billion colours for smooth colour-to-colour transitions, as well as enhanced grayscale performance. By displaying up to 1.07 billion colours, the VX2880ml delivers professional-grade colour accuracy and stunning images ideal for any multimedia application.
Equipped with 2 DisplayPort inputs and 1 DisplayPort output, the VX2880ml supports daisy-chaining of multiple displays for multi-screen setup and easy cable management. Even with multiple displays daisy-chained to the VX2880ml, high-definition content and colour remains consistent across screens. Quad HD is supported on two daisy-chained displays (two screens total), while Full HD is supported on four daisy-chained displays (four screens total).
Integrated with Mobile High-Definition Link (MHL), the VX2880ml enables users to connect compatible mobile devices, such as smartphones and tablets, directly to the VX2880ml. This allows digital content from mobile devices to be viewed in stunning Full HD resolution on the larger screen of the VX2880ml, while also simultaneously charging the batteries of the mobile device.
LED backlighting enhances display performance, delivers an outstanding colour range, and adjusts contrast ratios for remarkably detailed images. ViewSonic's eco-friendly, mercury-free LED backlighting further conserves up to 25%* more energy when compared to conventional displays. In addition, LED backlighting provides for a slim, lightweight profile that saves desktop space.
ViewSonic’s proprietary Eco-mode feature is built into all LED displays, offering options to select "Optimize(75%)" or "Conserve (50%)" settings that save up to 25% power. Especially in low ambient light, Eco-mode adjusts brightness and improves visibility, while reducing eye fatigue and prolonging the display's lamp life. With Eco-mode, both lamp replacement and energy expenditures are reduced.
The ViewSonic VX2880ml has two integrated 2W stereo speakers for enhanced multimedia performance with crystal-clear stereo sound.
ViewSonic flicker-free displays deliver on the promise of more comfortable viewing. Instead of using Pulse Width Modulation that continuously turns the LED backlight on and off, ViewSonic flicker-free displays use DC modulation backlights that maintain a steady stream of direct current power—nearly eliminating screen flickering at all brightness levels by providing a constant LED light source. This lets you work at your computer, play games, or watch movies longer – without eye fatigue.
Prolonged exposure to certain levels of blue light can cause eye discomfort. ViewSonic displays feature a Blue Light Filter setting that allows users to adjust the amount of blue light emitted from the screen, enabling longer viewing times and increased eye comfort for work and multimedia applications.
The ViewSonic VX2880ml features a 100 x 100mm VESA-mountable design that allows the display to mount on a monitor stand on a wall, depending on specific needs.
Enjoy excellent performance and accurate colour rendering for everything you view on this display. With 5 different scenario presets, ViewSonic displays offer best-in-class calibration techniques to bring you the best digital viewing experience. This includes Game, Movie, Web, Text, and Mono presets to enhance black levels in games and movies, colour lustre for online images, and colour temperature for reading text.
Specification:
- Size with stand (W x H x D ) : 659.96x510.58x240 (mm)<br />
- Without stand (W x H x D ): 659.96x412.46x52 (mm)<br />
- Packaging (W x H x D ): 732x462x162 (mm)<br />
- Display Screen Size: 28" (70.8cm)<br />
- Aspect ratio: 16:9<br />
- Panel Type: TN<br />
- Brightness: 300cd/m2<br />
- Contrast Ratio: 1000:1 (Typ)<br />
- Dynamic Contrast Ratio: 50,000,000<br />
- Resolution: 3840x2160 (30Hz)<br />
- Response Time: 1ms (GTG)<br />
- Color Support : 1B<br />
- Viewing Angle (H / V ): 170 ° / 160 °<br />
- Connectivity: 1x MHL 2.0 (HDMI) (30Hz), 1x DisplayPort (30Hz), 1x Mini-DisplayPort<br />
- USB Hub: NO<br />
- Speakers: Yes<br />
- VESA: Yes (100x100)) <br />
- Warranty: 2yr
Only £379.99 inc VAT.
ORDER NOW
30Hz so not a (fast-paced) gaming monitor.
TN so not a very accurate non-gaming monitor.
What were they thinking? Oh well, it IS cheap so somebody will buy it thinking they're getting a bargain.
If you want a better monitor, you pay more for it. Such a bunch of bloody moaners on these forums! :rolleyes:
It's nice to see cheaper monitors coming out, for those who just want a bit more real-estate to work with.
Or another way to see it, maybe someone who doesn't know better will come in here, see the comments and be put off buying something that will disappoint them :rolleyes:
Edit: especially when the title says 'gaming' monitor.
In first paragraph gibbo says not ideal for gaming. So which is it as far as ocuk is concerned?
To be honest that gaming bit should be removed.
While I agree it's nice to see 4K monitors coming down in price, this really shouldn't be marketed as a 'Gaming' monitor. I can barely cope on the desktop at 30Hz, let alone gaming. :/
30Hz?! No thanks, what good is that, apart from looking at colours and watching movies?
I'd rather on a proper tv for that.
It's a typo, I've already stated we don't recommend it as such for gaming in the OP, I shall fix that tomorrow.
Sorry I missed that. For all the slating it being only 30Hz this would actually be pretty nice for me (and many other flight simmers) who fly with a fixed FPS @30!:)
