- 22 Mar 2009
- Cornwall
i have read a lot about if you go over 1.4 vcore then you can damage the chip, but is this the same for lowering the vcore?
i still have a stock cooler so im trying to get the temps down. on stock settings under load it was going over 80deg, i lowered the vcore to 1.10 and it dropped to 77deg under load. i then bought 2 8mm case fans for the rear of my pc and got it to 74deg under load. so i then lowered vcore to 1.00 and its now 72deg under load. dont want to go down further if its going to cause problems or damage my chip.
