Make your own, get hold of Code39 font, and create them in Word, job done.
There is, but it would be more expensive I guess,
what information are you looking to put in the barcode?
I see now, there are software programs out there, a quick google for "backup tape LTO barcode software" brings back a few downloadable results..
you could do my method using Excel I guess, still a bit of work![]()
How about this, it will generate the labels you require into a PDF, you just have to print them.
I've used it and it works, but do test them in your library first, self printed labels can't always be read reliably.
Excellent.
This seems to work fine. I just need to find the labels now.
Thanks
Andy
Our offsite storage company generate ours when we purchase the tapes, but occasionally we loose a few label.
We just colour print replacements on a A4 sticky label, cut out and stick onto a piece of thin card. Never had any problems reading the labels.
We recently spent teh £30 on them, and they work flawlessly, you get loads, they are also colour and number coded so u can have sets.
£30 is nothing when you've just spent £2k on a back up device.
That would have gotten us......30 labels. Iron Mountain rocks!! (not)
