LTO3 tape compatibility
17 Dec 2004
If its a lto drive any lto tape should work no problem (so long as its less or equal to the number), for the sake of £3 i'd get the HP tape regardless though.
Ummm i might risk it then, as they are like only £6-7 on ebay. Its just because the drive says use the C7973A tapes and that makes me think that other LTO3 tapes wont work..
