LWB Big Rear Space - £50K ish (or ideally less)
Damn you're right - the LWB is crazy long:
Left hooker tho
Left hooker might be better for the continent though. It’s an idea. Although it’s not a left hand drive?
If you wanted a performance engine then something like this would be my choice -
M760Li
Although I'd just look for a high spec 730/740. The 760 comes with just about every factory option as standard.
In an ideal world you'd want AUC, or at least the BMW warranty on it.
I’d test drive a L405 Range Rover, ride is superb if you stick to the smaller alloys not bad with 22”s but noticeably better on 20s.
You’d get a TDV8 LWB Autobiography for your budget which comes as standard with executive rear seating.
M760Li
That would be a very nice place to soak up the miles. 3.7s to 60 is mad for a car that size. Fuel economy would be killing though?
