M.2 and PCIE 1x
Permabanned
28 Nov 2006
N Ireland
So am i right in what i read on the spec sheet that when you use the 1x M.2 slot it will disable all the 1x? Is M.2 just a re-route of that bandwidth? Because i am on Z87 and if this is the case i am better off as i need my 2x PCIE 1x slots.
Nah boards like extreme 6 have one m.2 slot for drives that uses it i am not sure how they work but it is 1GB sec nearly twice the Sata 6 bandwidth. But from the motherboards it seems that it only works if you give up the pcie 1x slots.
I just wanted to see if it was worth going from my UD4H to Z97 thats all.
