M.2 Storage advice questions? - ASUS TUF Gaming X670E Plus WIFI.
4 Nov 2022
El Mundo
Hi,
I just wanted to ask for some opinions and advice on the following.
This is the motherboards setup: https://www.asus.com/uk/motherboards-components/motherboards/tuf-gaming/tuf-gaming-x670e-plus/
4 x M.2 Slots
» 1 x M.2 2280 PCIe 5.0 x4 Mode
» 2 x M.2 2280 PCIe 4.0 x4 Mode
» 1 x M.2 22110 PCIe 3.0 x4 & SATA Modes
I have:
1 x Samsung 990 PRO 2TB PCIe 4.0 (up to 7450 MB/s) NVMe M.2 (2280)
1 x Samsung 990 PRO 1TB PCIe 4.0 (up to 7450 MB/s) NVMe M.2 (2280)
1 x Samsung 980 PRO 2TB PCIe 4.0
1 x Crucial P3 PLUS 2TB M.2 2280 PCI-e 4.0 NVMe Solid State Drive
I'll be upgrading to Windows 11 hopefully today if my thermal paste arrives, as I am upgrading to a 7800X3D.
My plan is to install Windows 11 on the Samsung 990 PRO 2TB and using that for latest game installs.
Keep the Samsung 990 PRO 1TB installed as a secondary boot drive with a current installed copy of Windows 10.
Use the Samsung 980 PRO 2TB as my Steam library for older games.
Use the Crucial P3 PLUS 2TB as a storage drive. - Install in the 1 x M.2 22110 PCIe 3.0 x4 slot?
Do you think this is a good plan or am I overlooking something here?
Thanks in advance for any replies.
the only conflict on motherboard spec is about SATA drives which you don't use
** M.2_2 slot shares bandwidth with SATA6G_1&2. When M.2_2 runs at PCIe x4 mode, SATA6G_1&2 will be disabled.
pretty much won't make a difference where you put any drives. Makes sense to go with boot drive in first slot.
I would use PCIe 3.0 slot for drive that is accessed the least - secondary boot drive maybe?
Ok. Cool. What if I plan to do benchmarking between Win 10 and 11?
Wanted to say that you will be the first to find a meaningful difference between pcie 3 and 4
But then again when benchmarking you want to remove other variables, so sure, keep it pcie 4.
Sounds fine, be careful how you handle the install process.
