m.2 wifi card help
2 Dec 2019
Hi Guys,
I've recently bought a DELL PC but it is not WIFI compatible. So I've bought a WIFI card to solve this but it does not come with cables or antenna's. (just a loose card) Please could someone advise what cables or antenna's i would need?
information below:
WIFI card i've bought:
V91GK - Dell CRD WRLES M.2 QCA9377
PC i've bought:
GTKGH -DELL OptiPlex 3060 8th gen Intel® Core™ i5 i5-8500T 4 GB DDR4-SDRAM 500 GB HDD Black Mini PC
Thanks a lot
What WLAN card did you use? Did it come with cables?
My computer came with a WLAN card which worked out the box without antennas but could only do 2.4Ghz So I bought a Addon Awp 1200E which was the same except it can do 5Ghz
They both came with antennas but i never used them and it still worked fine
