I'm having an issue with an M2 drive not being detected on my new build.
It's a Samsung 860 Evo 1TB SATA 3 6Gbs. Build, AMD Ryzen 7 7800X3D Asrock B650 PG Lightning.
I've flashed to the later bios and no difference ![]()
Its not an m2 drive that Samsung drive is a sata SSD which you need cables to connect to the motherboard.
Sata cable , Sata power cable.
Ah ok, that could be it then. It's in the the last slot near the bottom of the board.I've had a look at your motherboards manual and it's not 100 % clear but it may not support M2 SATA drives
An M2 drive is just a form factor and there are two protocols use to communicate. You have the older SATA like yours and the newer NVME ( PCI-Express)
I would make sure you have no other SATA drives attached and try using one of the two lower M2 slots as they are connected to the chipset. The top primary m2 slot will be linked directly to the CPU which is unlikely to support the SATA protocol.
I'm pretty sure it isIts not an m2 drive that Samsung drive is a sata SSD which you need cables to connect to the motherboard.
Maybe you put it incorrectly in the first post as it states SATA 3 6gbs which is not an m2 drive.I'm pretty sure it is
It's not exactly correct it dont put m2 in there google brings up the older sata SSD.Yes that is exactly correct as he put it. - SATA 3 is the protocol it follows and 6gbps is the maximum speed regardless of the interface.
I googled Samsung 860 Evo 1TB SATA 3 6Gbs which brought up an old Sata 3 SSd to check the type interface the drive is .SATA 3 is the protocol, M.2 is the interface, what has Google got to do with understanding the technology?
Do the same and see if you get the same results.
It's all good were all just trying to help.My mistake I should have put M2 in the description of the drive. Sorry for any confusion.
