M2 drive
19 Oct 2002
Torbay, Devon, UK
Hi alli have an MSI B450 Tomahawk Max.
I was looking into a M2 drive, and didn't realize that there are 2 versions. (Luckily I didn't buy one yet).
So it looks like I have an M2 SATA connection.
So my question are they better than standard SATA drives.
Specs say it supports PCIe 3.0 on the M.2 slot which would be expected on a board of that generation.
If it is actually M.2 SATA only then it's no better than a standard SATA drive from a performance point-of-view.
The B450 Tomahawk Max uses PCI-E 3.0 X4 (NVME) as bremen1874 says for the M.2. It disables SATA ports 5&6 when installed though, but you'll still have SATA ports 1-4 to use.
