M2 iPad not fit for purpose
20 Jul 2008
I’ve had the M2 iPad Pro for around 8 months now. When I try and edit RAW photos in Lightroom, or do other intensive tasks, after a short while (in some cases 30 seconds) the screen dims to the point where it’s not even usable. It’s not a software issue, this happens across many different versions of iPad OS and Lightroom.
Apparently this is a safety feature designed to stop the CPU from overheating and protect other components. I’ve seen this happen with my iPhone extremely rarely but it seems to be very common with the M2 iPad. Adobe pretty much said the same - and all I can do is enable ‘battery saving’ mode which stops the screen dimming but then the performance is terrible.
I find this frustrating and it seems to be a major design flaw of the iPad Pro. Why bother fitting a V12 engine in a car and then not giving it adequate cooling so that after a few minutes of spirited driving the power is bottlenecked— what is the point of the V12 in the first place?
Reason for this thread is I want to know if any other M2 iPad Pro owners experience this issue? To be honest I’ve just been living with it but I’m getting more and more into photography and it’s starting to grate now. I have Apple Care Plus so I may ask them to send me a new one if other people aren’t having the same issue.
1 Oct 2006
Apple have always been form over function when it comes to cooling.
Their Unibody MacBooks used to get so hot the Nvidia GPU chip would detach from the board. Fans running at full tilt just to run a second display etc. Apple have been hit with class action lawsuits over their less than adequate thermal designs.
You have a passively cooled device, which although has a very low TDP will heat soak over time as the device cannot dissipate the heat.
The price you pay for silent, slim device.
Fast, cool, silent. You can only pick two.
17 Sep 2006
Gloucestershire
Did you post in the iPhone 15 thread?
I'll reply here again, but I have an M2 iPad Pro and haven't had these issues. I'm editing XT-5 RAW files on it without an issue, and have'nt had any overheating from it at all in any use.
I'll admit I've not done super heavy sessions (like hours) but even up to an hour or so it's been fine. (to the point I've held off getting a new Macbook or similar as it seems up to the job).
18 Oct 2002
Cambridge
I’ve done some pretty heavy work on my M1 iPad (sustained large video encoding etc), and it’s never gone beyond slightly warm to the touch. I appreciate that yours is a newer model, but I’d agree that something is amiss.
OP
20 Jul 2008
Yes was going to mention I did as that was the reason for posting this to get a feel for whether anyone else experienced the same issues. I cannot edit XT-5 RAW files for more than 45 seconds before the screen dim kicks in, let alone "heavy sessions"
17 Sep 2006
Gloucestershire
Yeh that's not right. I was editing RAW files for about 20 mins last night with no issues at all.
Caporegime
9 May 2005
Cambridge
I got my M1 iPad Pro switched out under warranty because it would get stupidly hot. It would get hot just surfing webpages let along playing a game. They checked it out and agreed the fault and replaced it. New one hasn't suffered that issue.
OP
20 Jul 2008
Thanks very much everyone, feeling very lucky I took out AC on it now. Will give them a ring and hopefully get it replaced. If I can get one that does all the Lightroom work without overheating then it really is the perfect device for me.
27 Mar 2010
Yeah get this to Apple. This doesn’t sound right at all. I am the first to admit to apples shortcomings but my M1 iPad‘s performance isn’t one of them
