Hey guys, recently iv been getting a lot of BSODs totally out of the blue. No pun intended, im currently incapable of humour!
Initial thought was probably an unstable overclock. So i spent hours tinkering in the bios. refining settings lowering clocks stress testing. No BSODs! Excellent. So on i go and a few hours in BSOD again. Here rage starts setting in. Eventually i drop all overclocks and continue to get them!
Using a tool i forget the name of, I managed to find that the BSOD was due to "CRITICAL_OBJECT_TERMINATION" And according to the internet this is a problem with my OS being unable to read files. Ok perhaps windows screwed up so im on a fresh install, problem still there. fresh install on my mechanical drive. Problem solved!
So this leads me to believe my 128gig crucial M225 is kaput!
SSD life shows it as in excellent health. But the bar that the bottom says 24% (low in my opinion for something in excellent health!)
With only 10k hours of use it would appear as though the drive has degraded a lot. It is an old drive and would I be able to return it under warranty?
Sorry for the long story.
TL
R SSD seems to be degraded, causing BSODs. Do I have enough grounds to return under warranty or will i be charged shipping back and be stuck with it? Do they still make the M225 and if not would I get a sneeky upgrade? Afterall it costs me £280 back then Inc VAT :/
TL
