- 14 Feb 2023
- London
Help. I got flashed on the M25 I have had my licence for 7 months. Will I lose my licence? It was showing 40mph and I think I was going around 42-45mph. Pls help as I am really worried.
Or someone else got flashed and OP thought it was them. Most cameras are set to ACPO guidelines which is +10% then an extra 2MPH However not all forces follow this. In OP’s case they’d have been ok doing 45-46 to account for Speedo inaccuracy.You won't have been flashed doing a needle indicated 42-45 anyway, so must have been going faster![]()
Not speed.What should I do?
Lube upWhat should I do?
You'll find out in approx. 14 daysI also got flashed once idk if that makes a difference?
Ah 1 flash is ok. That's just a rub cuddle.I also got flashed once idk if that makes a difference?
What should I do?
What colour was the flash?I also got flashed once idk if that makes a difference?
What should I do?
Wit-whooLet me introduce you to @Diddums. He's also going away for speeding. Maybe you two can be cellmates.
