M4 slow read and writes can you help ?
26 Jun 2010
west yorkshire.
initially i had problems after installing my new psu. windows would boot but not get to windows it would bsod. so i ran the repair utility before the windows logon and it ran chkdsk and recovered bad sectors.
works fine now, logs on, has my wd cav black drive in for storage.
now when i run as ssd i get this
i have a sata 3 cable from both cav black and ssd going to the 2 sata 3 ports on the mobo. surely this should be a higher value ? i cant fault the ssd its blazing fast in the real work but if im meant to get better performance id like to think it was working correctly.
hope you can help, thanks.
hmm i only installed last night. i installed it onto my fresh ssd but only had a sata 2 cable even then had 276mb read. so when i swapped out psus today swapped cables for sata 3 this is what i get after that dodgy chkdsk thing. you sure i should re install ?
Hmm it looks like IDE in that screenshot, also does the X58 use the marvell chipset for the SATA III ports?
i believe so, i just installed all the chipset driver to see if anything would give, i remember marvel 91xx something
so ill reinstall and clear both hard disks. delete everything off them both. ill reinstall from flash drive then see what happens. its set to ahci in bios
Well I'm installing now I went to BIOS to check ahci upon doing it I realised I could scroll down and there were more ahcis to enable as well as setting driver to on chip. If that works then I guess it wasn't the reinstall
getting same speeds :/ only the 4k one ( one after read and write) dosent even seem to finish. max 370 read max 160 write
