what size ssd do you have? The read/write rates vary with different models. My 128gb M4 performs slightly above spec with atto and bang on spec with Crystal disk mark........
Just read a few of your other post's and gather that you have a 128gb M4 ssd, (Snap) your writes seem good,(same as mine) but i'm getting 435974 read with atto, so your reads seem a low to me tbh.
Hi, Went to this download. Paid the donation but can not see how to actually download it?? i thought that after going through paypal it would allow me to download it.
Im going nuts today. Trying to do too many things at the same time. Already managed to completly wipe my Iphone4 by just updating it and lost everything in the process. back to factory defaults.
You should be achieving on or around 415mb sequential read with your 128gb M4 SSD, follow Mr. may2's advice above, something is not quite right on your reads.
once you have sorted your sequential reads out maybe you could look at selling your 5670 for a 6870 or something, it is your weakest part in that build.
On the Storage Configuration page in the BIOS there is a setting for SATA mode which is IDE, AHCI or RAID. Ignore the setting for Marvell SATA3 Operation Mode.
If you've not changed this it's likely to be in IDE mode and you need to change it to AHCI.
But you can't just do that otherwise your system won't boot.
So first make the changes in the link, then restart your PC and go straight into the BIOS, change the SATA mode to AHCI, save the changes and the PC will start again.
Try your benchmark again after you've done that.
If for some reason it doesn't boot change it back to IDE mode and try booting again.
