M4 SSD upgrade firmware before or after OS?
4 Nov 2010
Ok so tomorrow I am building my new system (if it all arrives) and have got the M4 Crusial SSD.
I see there is an update 009 (I think) that increases read and write times. Before I install windows am I best to update the firmware?
Ie. Plug SSD out of box to my current system, upgrade the firmware and then build my new system and when it boots up windows installation will take care of rest?
OR
Install windows with new system and then update forward after?
Over to the guys in the know ;) also if it's the first one, updating the firmware won't alter the SSD in anyway and will be able to just build pc and install with no problems!?
Doesn't really matter either way but you need to have your SATA controller in IDE mode to perform the update, whereas you want it in AHCI mode normally. So doing it before installing Windows involves slightly less hassle.
Thanks guys, will attach to my current system that is in IDE mode and update it, then will take all old parts out, install my i5 stuff and then boot it up with just SSD attached, change bios to AHCI, then put installation of windows 64 in DVD drive (inset this as first boot in bios?) and let windows install and do rest.
Do Windows Score check (heard this tweaks ya SSD and also turns off defrag etc)
Then disable Hybernate.
Then am guessing everything else will be god to go am guessing? (well then update motherboard, then graphics firmware)
That sound bout right?
Guys, I bought one of the Crucial M4 64gb drives when they were quite new back in 2010 and I have still not got round to using it. It's possible it shipped with original version 1 firmware. There weren't different revisions limited to certain firmware types were there? I mean there's no possible way I can muck it up flashing to 009 firmware? What are the differences in speed between them then?
The new firmware provides a major increase in read speeds so it's worth doing. Easy enough to do as well given Crucial provide a bootable iso that does it for you.
Sequential Read (up to): 415MB/sec (SATA 6Gb/s) - 550MB/sec with firmware 0009
Sequential Write (up to): 175MB/sec (SATA 6Gb/s) - 200MB/sec with firmware 0009
