Hello all,
Took the plunge the other day and bought a apple mac mini while @ work in Las Vegas, now I'm a newbie to mac but been using pc's for 10 or so years.
Questions really maybe basically simple to most, but (a) I don't have the time to visit a 'Genius @ a mac store' (b) I don't think you have to be a 'Genius' to use a mac
lol.
So first up is, my mac os x is a US version so can I still change the keyboard region etc so the '@' key is above the shift key not on the number 2 key? (My keyboard is a Logitech di novo, hence the option of Mac mini makes it easy to upgrade from an older system or set it up side-by-side with another computer. Just BYODKM — bring your own display, keyboard, and mouse.)
Second question is, I've installed 'Microsoft Office Mac' all works but I want to keep the icon on the dock (bottom of screen) for a quick start up of the program. I dragged the icons to the dock and 'Entourage' works fine from here, but 'Word' or 'Excel' doesn't.
Any tips appreciated, and many thanks in advance.
Cheers
lol.So first up is, my mac os x is a US version so can I still change the keyboard region etc so the '@' key is above the shift key not on the number 2 key? (My keyboard is a Logitech di novo, hence the option of Mac mini makes it easy to upgrade from an older system or set it up side-by-side with another computer. Just BYODKM — bring your own display, keyboard, and mouse.)
Cheers
