Hey i've just purchased a Macbook 2nd hand and i can not get the internet to work i get this message :
"Safari can not connect to the Proxy server"
It says to go to Safari preferences then to advanced and to change the proxy settings however the button is greyed out.
Now i noticed on System > Accounts > Login items There is a item
smb://4062-xserve-01.rts.school.leeds.pri/mediashare
Could this be the proxy it is connected to? And how do i go about removing this as it says "you cannot change login items because login items prefrences are".. ( cant see the rest )
Thanks in advance.
Thanks in advance.
