Mac Studio wifi - any way to improve it?
The wifi on the Mac Studio is crap to put it mildly what with the location of the aerials. Is there any way at all to improve it?
I don't believe there's any 'mods' you can do to the Studio to make it better, so your only real options are to move closer to the router/AP (or visa versa), WiFi repeater, use an external WiFi adaptor, add an AP nearer to the Studio or Powerline adaptors.
I’m sure it is but I really don’t want to drill holes anywhere. I found a temporary solution in upping the transmit power of the router. A quick Speedtest and observing the connection over 24 hours shows it’s far more stable than previously. Still not fast but good enough for my use case
A lot of the times you don't need to drill holes. You can either work with the holes you already have or use flat cables and pass the tables around the corners and hide them well. Powerline adapters are also worth a look.
I tried Mikrotik Pwrline Pro adapters and they were disappointing especially given their reputation.
My Mac is upstairs while the router is downstairs. Not far but awkward enough to make it not straightforward
Use powerline ethernet.
Edit: Ah, just seen your previous post. Ignore.
