- 19 Dec 2010
- The south
Just bought myself a rather lovely 15" rMPB, and obviously i'm rather going to look after it!
I know from using laptops that it is bad to keep them charging constantly, i'm guessing this is the same with my rMPB? I've done some research into how to use the battery so it lasts longest, some say discharge to about 75-80% then charge, some say its fine to keep it charging as long as its discharged once a month, and others say drain it to about 10% then charge fully.
I know that you ideally want the least amount of cycles, but is it just a balancing act between no. of cycles used and keeping it charging?
Mike
Mike
