Macbook resolution question
19 Oct 2004
Newcastle Upon Tyne
Hi guys,
Can anyone tell me if I hooked up a Macbook to an external monitor via VGA cable would I bet able to set the resolution to 1360x768 on the monitor and also have the Macbook closed while I am using it on the external monitor. Does it come ready able to do this or does it require lots of fiddling?
I can only use 1360x768 as thats all my monitor supports.
Cheers
Yep, you certainly can. Just plug the monitor in, apple>system preferences>displays>arrangement then select mirror. Close the lid, then choose resolution on the monitor.
Easy as that.
Thanks Justin,
Sorry for the seemingly daft questions, I changed my mind from the iMac just thinking about a Macbook but I've never used them properly before so have lots of dumb questions before I spend the cash.
Regards,
Graeme
the macbook is by far the best choice out of all the macs... its can used as a desktop replacement via external screen, keyboard and mouse AND is amazingly portable!
Hi guys,
Does anyone know how to get my macbook to support 1360x768?
I connected it up via the VGA cable but the non of the resolutions on the list are compatible?
Im gutted, £20 wasted if I cant get it working. :(
Don't worry!!!
It's probly your TV sending duff DDC information to the Mac - I had the same problem with my 32" Panny. I used a utility called SwitchResX which allows you to create custom resolutions, then input the timings from the back of the manual. Now it's perfick... :D
