I had my Mach II delivered last night I have installed it and it seems to working fine but I am having trouble getting my PC to post regularly.
I have just got online at about the 20th attempt, once it is running it is fine but if I change an option in the BIOS it won't POST.
I don't think it's a problem with the Mach as there are no error lights showing, could it be the cold bug?
It could also be the chip as it had the IHS removed by the previous owner and there is a pin missing, having said that it worked 24/7 at 2.35Ghz under water.
Stepping : CDBHE 05335 PDW (from auction site ad)
Evap head temp : -56 C
, will experiment more tomorrow, also noticed that the hose covering has come loose where it joins the head, I'll have to put some sealant string on it.
