machine reboot cycle
6 May 2009
Sometimes when I power my computer on, the fans all start up, lights come on and everything for about 5 seconds then it reboots, fans go off then back on....
If I leave it it will eventually get to the post screen and start windows fine. This started happening yesterday randomly.
My CPU is not overclocked.
CPU passes prime small fft and blend
Memory passes memtest (and prime blend)
PSU is fine in OCCT when left running
I took the cmos battery out for a few mins then put back in and it started up. I did this another time and it did not work
Anyone have ideas what it might be?
Sounds like it's shorting
Why do you think it would be doing that? I hoovered it out yesterday
I have just left it off for a bit and tried turning it on, it turned on first time. I read that sometimes power buttons stick and cause it to start then because its still pressed in, to restart straight away.
I lightly tapped the power button instead of pressing it in and it turned on. I think it might just be the power button, strange. I will check this tomorrow when its been off all evening/night and update this thread
Just going on what caused my boot loop, a fan cable was touching the motherboard, as soon as I move it, it stopping looping
Try plugging the reset switch cable in to the power button one and use that to turn on PC, then see if it still turns off. Atleast it will rule out the sensitive power switch if it still does it.
Strange, now it stays on, but does not post. No beeps or display on the monitor or anything
Something weird is going on.
