Machine running slow?
16 Jun 2006
I think i have a hardware problem as a fresh install off windows is showing the same problems. In the vista sidebar it always shows my second core to be running above 25% and there is nothing running in the background. I dont remember seeing this before. The pc is running really slow in games and opening up apps.
Any ideas?
gonna need more than that..
specs?
os?
updates applied?
programs running?
screenshot of task manager
here is the info
OCZ GameXStream 600w Silent SLI Ready ATX2 Power Supply54.99
Antec P182 Super Midi Tower Case
Sony NEC Optiarc AD-5170 18x DVD±RW IDE Dual Layer
Microsoft Windows Vista Home Premium
OcUK 4GB (4x1GB) PC2-6400C5 800MHz DDR2 Dual Channel Kit
Intel Core 2 Duo E6600 "LGA775 Conroe" 2.40GHz
Samsung SpinPoint P 250GB SATA-II 8MB Cache
BFG GeForce 8800 GTS OC2 320MB GDDR3 HDTV/Dual DVI
Zalman CNPS7000B-ALCU CPU Cooler
Gigabyte GA-P35-DS3R (Socket 775) PCI-Express DDR2 Motherboard
programs open instantly
on my 8gb system, vista has about 10mb free (superfetch using it), everything opens really quickly
i've since moved back to xp64 though, as gaming seems better in that
dunno, the only dx10 games i have are COH and Crysis, they run too jerky on my 8800gt (compared to dx9), so atm i play at dx9 anyway
