Check the fuse, better still smash it and buy a new one from here http://www.overclockers.co.uk/
Ure all quite funny cheers for nothing!
If you're going to get all sarcastic when people offer you help on what was a really poorly explained problem, then screw you! Figure it out yourself.
ye ive tried with another monitor. if it was the gpu if i took that out and tried it on the mobo output would it then work if the problem was the gpu?
